Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1970 Vragen Bekijk alle
My phone will not stop crashing!
Hello all!
My iphone 3gs will not stop crashing about 10 seconds after I restart the phone. Is this a battery issue?
HELP!!
Is dit een goede vraag?
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
2 Antwoorden
Het nuttigste antwoord
natalie, given the age of the phone, it is entirely possible that your issues are related to a bad battery. Use this guide to replace the battery and make sure that you get the right battery when you replace it. This model iPhone is finicky about its battery and does weird things when the battery fails. If nothing else, it will provide you with a known-good starting point for any further trouble shooting. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
I would try and replace the battery, but this is most likely a logic board issue because of the age of this device. In my honest opinion I would upgrade.
Commentaar:
Josh Forester, what would age have to do with a logic board issue?
door
Preview
There has been more time for accidents to occur, parts to fail, and moisture and dust to ecumulate inside the phone.
door
Voeg je antwoord toe
natalie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 56
