Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Vragen Bekijk alle
Any luck on replacing a Dock Connector?
Attempted twice and afterwards the device fails to initialize that the charger has been connected.
Anyone had any luck with replacement?
Is dit een goede vraag?
Score 2
1 Opmerking
Has anyone been able to successfully replace an iPad Air dock connector?
Thanks
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
The dock conector that was replaced is original or at least a good quality?
Can also be a component that is responsible for identifying the cable does not work in this case would be very hard to fix it ... unless there the same component on the iPhone 5/5S and then to replace it buy soldering
Was dit antwoord nuttig?
Score 1
1 Opmerking:
The dock connectors were purchased from etrade supply, so I would consider them pretty good quality. The solder tech I had replace the dock connectors is one of the best soldering techs I have seen with over 20 year experience. I inspected his work under microscope and the soldering job is flawless.
I have received the cable error message a few times when connecting the lightning cable to the device. I have ruled out cable brands as I have tried OEM, MFi certified, and other ones; still comes up with an error message.
Which component do you think I should consider looking into to replace?
Thanks,
door
www.mycelcare.com in dubai.. i am their client too. trustworthy centre
Fault does not recognize the cable reminds me of the problem of the iPhone 5 u2
U2 responsible for identifying the cable and serves as a kind of starter while charging, try to search the component is similar but the problem that this device dont have scheme
Score -1
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,425
