Ga door naar hoofdinhoud
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why won't it turn on after screen replacement?
I just made a screen replacement on an RAZR and it looks like it won't turn on. I made the repair following the guide. When I plug the charger, a white led turns on. I tried to hard reset it and nothing happens. What could it be?
Is dit een goede vraag?
Score 3
1 Opmerking
I've double checked it and it's connected. When I try to reset it. The logo comes up but instead of start up it just goes black and nothing work.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Have you checked the connections of the three display cables?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Today another RAZR came in with a similar problem and the battery flexible was ripped. So it might have something todo with it too.
door
Question: Did you check the battery? Of the RAZR from your original post?
door
Voeg je antwoord toe
Edgardo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,168
