Problems with the SIM card holder slot tray
I was using a nano sim in my Nexus 4, using an adapter. When removing the adapter to go back to a normal micro sim, i think that I damaged the internal tray: after that I got the error "sim not found" from time to time in the phone, and after a while the inserted sim was not recognised. I have tried with several cards, all the same problem.
What is the procedure for replacing the internal sim card holder? I found some in ebay, and if not very complex, I will try to fix it myself.
Thanks in advance.
Is dit een goede vraag?
1 Opmerking
Do you mean the tray that is listed here as a replacement part, or the internal slot that the SIM card tray slides into? If the former, you can buy one for $4.95. The latter ... examine the tear down and determine which internal board holds the SIM card tray.
door David Spalding
