Ga door naar hoofdinhoud
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
220 Vragen Bekijk alle
Turn off touch pad on gateway laptop mt6728
I now have wireless mouse. I want to turn off the touch pad on this lap top. Can anyone help?
Thanks, John.
Is dit een goede vraag?
Score 1
1 Opmerking
If one of the answers fixed your problem, you should accept that answer. Thanks!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This is an add-on to Josh's answer but a different answer:
Well, different laptop manufacturers have different add-ons to the ctrl panel, and if you ever reformatted, chances are you don't have these options anymore as the software is not installed. Try installing a mouse software (I know Lenovo has one) or the general app suite
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Gabe&Josh,
you gave me some ideas about reformating. I found synaptics and downloaded the device settings for the touch pad and it solved my problem. I can enable and disable OK now. Thanks for the help.
John.
door
Het nuttigste antwoord
With Windows, I believe that if you go into the Control Panel and open the mouse preferences, you can tell it to ignore the trackpad when a mouse is present. Try that out. :)
Update #1
Okay, is there a separate trackpad toggle somewhere? I know that with some PCs, the trackpad has its own set of preferences and controls.
Score 3
3 opmerkingen:
This is true +
door
Hi Josh,
I have tried the control panel route. In the mouse box it only gives me the mouse preferences and says nothing about touchpad. I may have at sometime disable a toggle or deleted something that refers to the touch pad? maybe it is driver problems. I only have limited knowledge about computers. thank you responding to my ?.
John.
door
Voeg je antwoord toe
john zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 807
