Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Vragen Bekijk alle
Vraag afgerond
Does not wake up from sleep
I have an iMac 27 mid 2001 that does not wake up from sleep. The machine stays on, fans, hard disk ok. The screen stays black once the LCD goes to sleep.
I guess is LCD, but not sure.
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The solution I found is to reconnect the display data cable and since a couple of days everything seems to be ok.
Was dit antwoord nuttig?
Score 1
Do you have access to an external monitor you can plug in? If you do give that a try. If you don't have a monitor and have access to a second mac see if you can access it via a network connection.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 138
