Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Vragen Bekijk alle
Vraag afgerond
Next step after replacing battery on water damaged iPhone?
I recently dropped my iPhone 4s into the pool. I immediately placed it in rice for several days and attempted to turn in on after with no luck. I then ordered a new battery which helped some. The screen is completely black but it vibrated when I turned it on and Siri responded with something like "unavailable at this time". I am not sure what I should do at this point. I don't want to keep buying random pieces to my phone but I need to get it fixed asap. Suggestions as to the next thing I should try?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Joelle, skip the rice. Placing your phone in rice is equivalent to doing nothing. It does not prevent any kind of corrosion or fixes your phone. The best thing to do is to stop using the device, (remove the battery) and to totally disassemble it. Use these guides for that. Then clean it with +90% isopropyl alcohol. This will displace the water and stop corrosion. It it okay to submerge a board in isopropyl alcohol. Check this guide to show you how to do it. After that, air dry all the components. Do not forget to clean the connectors on the board as well as the cables. Then re-assemble with a new battery This is not optional but a must to avoid failure later on. " Check your board for any missing or damaged component. Water damage is the toughest to trouble shoot and to repair. Hope this helps, good luck.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 77
