Ga door naar hoofdinhoud
15" HP laptop with 2.60 GHz AMD Phenom II Dual-Core Mobile Processor.
11 Vragen Bekijk alle
My fan is malfunctioning, how do I replace it?
My fan usually gets really hot, even when nothing is running on my computer. Also, when my desk gets bumped or knocked, the fan makes a god-awful noise and vibrates a lot until I restart my computer.
Does anyone have any tips in fixing this problem, if not how do I replace my fan?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Chris, download the service manual from here. Page 73 of the manual will tell you exactly how to replace the fan. Make sure that you use new thermal paste and clean your laptops air vents properly. hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
I've found that my laptop really overheats so I bought a Belkin laptop cooler cushion which you connect via a USB port. It has a cushioned side for your lap and hard durable surface for the device. It has an inbuilt cooling fan and really works well. It was around £30 from Amazon.
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,880
