Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 Vragen Bekijk alle
no cell service on my iPhone 5
does a wifi replacement fix this problem? my email is steven_oriordan@hotmail.com
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
Steven, you have to be more explicit on how this started in order to get help. Did it happen after a drop or a liquid spill or a repair you did for example? Is it CDMA or GSM? Is the signal intermittent or always off?
But basically, to start, if this did not happen after an incident of some kind, check the following:
- Are you using a metallic phone cover/case? If yes, try removing it.
- Is "Airplane Mode" ON by any chance? Turn it off.
- (For GSM models) try removing then re-inserting your SIM, then use another known good SIM. If the new SIM works, try cleaning your old SIM with a eraser, or replace it.
- Try rebooting: press and hold Home Button and Power Button together for 15 seconds.
- Try Settings>General>Reset>Reset All Network Settings but note that this will erase all your Wi-Fi passwords as well.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
steven zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 129
