Does replacing the charging port require soldering?
Does replacing the charging port require soldering? If it does, where can I get soldering tools?
Is dit een goede vraag?
Yes. You will probably need a micro-soldering iron. Check with an electronics store. You probably need a good amount of experience in soldering as well.
Was dit antwoord nuttig?
You should probably purchase a new motherboard since it is soldered on. It's pretty simple to replace
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 227
