Ga door naar hoofdinhoud
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
141 Vragen Bekijk alle
speedometer stopped working on 2005 Pontiac Grand Am
The speedometer needle moves on engine startup but not during movement of the car. All other instrument cluster needles move OK. Odometer is not recording any increase in mileage during movement of the car.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Theo, this is most likely a problem with the instrument cluster or the speed sensor. Instrument clusters made after 2000 have Stepper Motors to drive all the gauges including the speedometer. I'd start with the speed sensor since it is a lot cheaper. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Theo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 1,792
