iPhone not boot up, can not restored. Error 2001
iPhone not powered up, can not restored. Error 2001.
Booting up only from wall charger, charging. After country
selection-showing Connect to iTunes.
I try to restored from iTunes but every time same fault-2001. Some of the with the same fault has a battery problem. I replaced battery today, but still the same problem.
Is dit een goede vraag?
Leave on charger over hour. Still the same.
When phone connected to the charger after 5 min screen become grey and
phone stuck until disconnect
door Vitali
Previously has a minor water damage. I did pull logic board out and cleaned with alcohol. No any signs of corrosion or any other damages on the board.
door Vitali
Found short circuit at the battery connector at main board. Power I/O
is heating up when charger connected.
door Vitali
