Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
Can't show something on display.
I try to open the iPhone, but I forgot shut down the power,
take out the connecter 1, 2 and 3.
when i try to connect, but can't see something on the screen,
only black, have the sound, no touch function, no display.
How can I do?
Is dit een goede vraag?
Score -1
3 opmerkingen
I need wait the low power and do that?
door
yes, great.
you right, i try to connections, is successful, i thinks is no1 connecter problem,
thank you very much, you are powerful man.
door
you don't have to wait, the battery of the 3g isn't soldered to the logicboard. good luck
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would disassemble it again and check the connections - they can be very tricky
Was dit antwoord nuttig?
Voeg je antwoord toe
Leo Li zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 949
