Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
System won't read discs?
The system starts up fine, and I can fart around in the menus all I like, but when I put a game or movie in, it starts to load (in the event of games, it even shows the graphic on the menu), but it stops and powers off. Any thought?
Is dit een goede vraag?
Score -1
3 opmerkingen
Which version/update? Please amend or add a comment.
door
It is likely overheating OR the power supply is dying (voltage drops below spec). Those are the only two ways I know to force a power down. Could also be an issue in the power control chip.
door
Does the red LED flash before the shutdown?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would first try to check/clean the laser with a soft microfibre cloth.
use the following guide to disassemble it: Playstation 3 Optical Drive Replacement
but many ps3 lasers are "dying" - never had a "dead" one, but the ps2 had a similar problem and every ps2 i had with that issue, had "burned in" dust on the laser - i've cleaned it and everything worked as normal
Was dit antwoord nuttig?
Voeg je antwoord toe
Rick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,775
