Ga door naar hoofdinhoud
The Canon Powershot A1200 is a 12-megapixel point-and-shoot camera that uses an f2.8 28mm-equivalent wide-angle lens with a 4x zoom. It was originally released in 2011.
10 Vragen Bekijk alle
How do I repair a stripped Toggle Slide Switch?
The toggle / slide switch on this camera is broke (slides loosely between video / still photo mode, and the camera is stuck in video mode). Canon said the warranty doesn't cover it. Is this an easy DIY fix?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Is it easy? Depends on the camera. The broken part is not actually the switch, it is a piece of plastic which pushes the switch back and forth.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
How do you fix that? Is there a way to pop the back open, and switch it that way?
door
Voeg je antwoord toe
Randy Young zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,732
