Ga door naar hoofdinhoud
The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
16 Vragen Bekijk alle
What is the procedure for replacing my Dell laptop's keyboard?
My daughter's Dell laptop keyboard has failed.
Can I repair or replace it, or must the keyboard be repaired or replaced by a qualified technician? If I can replace it following a procedure, where might I find the procedure?
I don't see Dell keyboard replacement procedures in iFixit.com.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Check these two links:
http://support.dell.com/support/edocs/sy...
http://support.dell.com/support/edocs/sy... (This is the manual, the guide with pictures starts on page 109).
This info should be enough for you to be able to do it yourself. Also, it would be great if you could create a repair guide for iFixit for doing this. It'd be a great help to people later on who want to be able to do this
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Research + Ralph
door
check out this site: http://support.dell.com/support/edocs/sy...
1 Opmerking:
rab has already listed that site.
door
you can visit '''Dell Technical Support''' to resolve your issue. you will get a manual guide here from which you can easily learn about replacing dell laptop’s keyboard.
Voeg je antwoord toe
LeRoy Younglove zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 5,074
