when I load playstation home the ps3 freezes.
Hello,
I was gonna play playstation home and wheni loaded it it froze up on me
is it my ps3 or home?
Is dit een goede vraag?
Hello,
It sounds like the Playstation Home install is corrupted. I would delete it from the hard drive and download/install it again. If that doesn't solve the problem, there is also the possibility that it could be a bug in the Playstation Home software. I doubt that your PS3 is at fault. Are you able to play any other games downloaded from the PSN network?
Was dit antwoord nuttig?
I refuse to buy those 9.99 junky games
id rather buy MGS4 instead(own it)
If you can play other games and movies OK, then it is possibly PlayStation Home (the software), or the PlayStation Home disk.
Have you played/used Home before? If the disk worked before and does not work now, you may need to clean the disk.
I use a microfiber cloth and cool (not hot) bottled water to clean my DVDs and CDs. I have never cleaned a Blu-Ray disk, but that should work as well or better, due to the harder surface on the Blu-Ray disks
It is also possible that your PS3 lens is dirty - try cleaning it with either a CD lens cleaner disk, a DVD lens cleaner disk, or a Blu-Ray lens cleaner disk.
If the disk is brand new, and you clean the disk and the PS3 lens, and you still have the freeze booting up Home, then try exchanging the disk for a new PlayStation Home disk.
Here in the US, almost every store will exchange a new disk for free for 2-4 weeks after purchase when you have your receipt.
yes i have used it before
and also i have a system thats out of warranty
its software that you can download and install opitonally
Playstation Home is not on a disc. It's download only.
Yes you need to stop the heat build up internally to fix this problem and it is not as difficult as you may think. You can use a good repair guide that will show you how to do this or you can send it in and they will fix it for you.
Here is a good guide >> http://www.ylodrepairwizard.com
If you are getting freezing up on your PS3 this can happen before the red lights and it means that the GPU and the CPU are overheating in the system.
If you leave this it will no doubt turn into the red lights.
The way you can fix it is to send it in and they will fix it for you, although you must bear in mind that this can take about 4 weeks of waiting time and the other thing that you have to know is that you will have to pay out a repair bill of $150 as well.
The good news is that you can fix it yourself and to do this you just need a good PS3 Repair guide.
There are a few out there but to make sure that you get a good one we have listed the best with pros and cons so you can have a look HERE.
I hope this helps you and if so can you please rate so it can help others.
if i delete playstation home how do i get it back if i never downloaded it from playstation store
you can delete then re-install home, the home icon stays on your PS
I was speaking to PSN support earlier, it seems to be a common problem, its happening to me, but it will let me into home on my old account, it just freezes on my main account. The guy in support said this was common too. He said they are working on the problem and thought it would be fixed in the next couple of days. He suggested clearing my cache, obviously by accessing home by my old account but it didn't work for me.
My playstation home freezes when I go to a destination I don't know why but it just does I tried deleting it multiple times and it still wouldn't work I even thought making space would work but it doesn't
ugh how long till they fix it
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 5,306
