Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Vragen Bekijk alle
Why doesn't the keyboard dim in bright light?
Well, i bought a Brand-New MacBook Pro (mid 2010), and i'm having some technical difficulties with the keyboard backlighting.
If I am not mistaken, When the Ambient light sensor "sees" that there is enough light to see the keys on the keyboard, it should turn off keyboard backlighting and if there is not enough light, then naturally, the keyboard would brighten.
My problem is that the keyboard dims when there is not enough light to see the keys, but brightens when there is obviously enough light.
Whats wrong? Did I screw it up? How do I fix It?
Is dit een goede vraag?
Score 2
1 Opmerking
it won't let you manually adjust if it's in high light. that's what irks me.
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Sounds to me like the wires are reversed. Take it back to Apple for warranty repair.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
+ It's under warranty and they'll correct it.
door
I just bought a new 17" MBP, and I'm having the exact same problem. The old ones had a sensor under the speaker grill and the keyboard would brighten when you put your hands over it. The new ones have a sensor at the top by the iSight camera, and it behaves in the opposite manner. :( I'm calling Apple to find out WTF is up.
Score 1
3 opmerkingen:
Just got off the phone with Apple. The guy on the phone didn't even know they moved the sensor and argued with me before talking to a superior to confirm what I told him. He said they've had no other complaints about my keyboard lighting situation, but they are going to keep my case number active. He suggested waiting a while to see if this is a common issue. I'm heading to the Apple store now to see if their display models act this way.
door
Just got back from the Apple store. Their machines work as expected (keyboard light is off without any ability to adjust the light until you cover the sensor with your finger to simulate a dark environment).
So, I took my MBP over to a VERY bright light and BOOM, the keyboard light went off. So, I'm hoping that it's just my sensor that is very under-sensetive to the light. I'm going to find out though, because I'm taking mine into their store tomorrow.
Hope this helps.
door
Check out this thread for much more info on this problem: http://discussions.apple.com/thread.jspa...
door
One workaround is to use the F5 and F6 keys to manually adjust the brightness.
One workaround would be the App 'Lab Tick' (found in the Apple App store), which allows you to control the brightness of the keys.
Voeg je antwoord toe
Danny Arenales zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 5,534
