Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
battery seems to keep draining.
My computer acknowledges that the iPod is connected and it signals that it is charging. It also syncs music very well and also indicates charging on my Actimate docking station. But when I disconnect it, the battery seems to keep draining. And when I connect it to my Apple USB 12w adapter, it doesn't indicated charging or anything. I also bought a new USB adapter.
Please help -----
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Bona, I would replace the battery first. This way you have a know good starting point in case it is not the battery that is failing. The indication for that is "the battery seems to keep draining". Use these guides to work on your iPod. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bona zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 89
