Ga door naar hoofdinhoud
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Vragen Bekijk alle
ON boot up cannot use key board to login.
I plugged in USB external keyboard. Now the mac book pro 17" will recognize this. I could then type in my admin. However, when trying to use my track pad and curser to access any system items like safari or anything, computer would go to applications list only, instead of launching the application. track pad will move cursor around but cannot nothing more.
Only responsive to external key board and I would assume, mouse.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like you may have spilled something into the keyboard & trackpad causing both to fail.
Do you remember spilling something in, or did you open the system and forget to reconnect the keyboard & trackpad ribbon cables?
Review this IFIXIT guide Steps 16 & 17 MacBook Pro 17" Unibody Logic Board Replacement. Also make sure there is no damage to the ribbons as they do tear as well as the locking connector.
I must warn you replacing the top case is a very big job if the keyboard and/or the trackpad is damaged. Review this guide MacBook Pro 17" Unibody Upper Case Replacement. You will need to order the trackpad separately as its not part of the case.
MacBook Pro 17" Unibody Upper Case Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 3 hours
MacBook Pro 17" Unibody Logic Board Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
triggerfish zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 68
