Ga door naar hoofdinhoud
The fourth Google Nexus smartphone, released November 13, 2012.
75 Vragen Bekijk alle
Microphone doesn´t work after Water damage
My Nexus 4 was face down on my desk in a big puddle of water overnight. But it was in a rubber case, that elevated it a bit. The next day the microphone didn´t work any more and there was some discolored parts on the display. I let it dry in a bag of rice for 24 hours. The display went back to normal. Only the microphone doesn´t work ever since. If i do voice recording it only pics up static and tapping on it.
Is it possible to replace the microphone on the daugtherboard?
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
You will need to replace the mic. Here is the link to the part you will need. Very simple repair. Just unscrew the phone, logic board and pull the old mic/charging port flex off the board and click the new flex back down. Here is the part as long as it is the E960 http://amzn.to/1hPhSTH
Was dit antwoord nuttig?
1 Opmerking:
can please describe the procedure
door
Hi! I did as suggested by Jonathan James and the microphone now works well and I can charge the phone again :)
But I noticed a worse signal :(
Do you have any suggestion??
Thanks,
Arturo
Voeg je antwoord toe
Christian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,566
