If you mean the Windows password, you can follow the steps below:
1. Download Windows Password Key in another accessible PC.
2. Run the downloaded file and install it.
3. Burn a reset CD/DVD/USB with Windows Password Key.
4. Reset your Windows password with the created disk above.
If you mean the bios password, please refer to the following steps:
Step 1: Open your computer case to examine the motherboard. Remove the CMOS battery. Gently pry the battery from its housing and reinsert the battery after 10 minutes. If this works and you don’t see the password prompt, then you have successfully reset the BIOS password. Otherwise, follow the steps below.
Step 2: Locate the jumpers near the edge of the board or near the CPU or the CMOS battery. Find “Clear CMOS” or “Clear Password”. Place the jumper over the pins and restart your computer. If this doesn't work, try step 3.
Step 3: Enter a password after receiving the password prompt. If you have an Award BIOS, try “AWARD PW”. If you have a Phoenix BIOS, try “CMOS”.
7 opmerkingen
JEWELL, are you talking about your Windows password, or the BIOS password or the system password?
door oldturkey03
What can I do if is system password and I can't remember one ever being set?
door browneyedme
Ive tried everything but without my password for my PC i cant get into my computer
door Nicole
I had a PIN set on my computer. My son was watching a movie and the computer went off, when he powered it back up it came up with password. When I tried my PIN it came up saying "PC is offline. Use password that was used the last time you logged on" it would not accept my PIN. I'm assuming this is the windows password. But since I've never set one I don't know what it is.
door Boykinsm
UUkeys Windows Password is a great tool to reset windows local password. I tested it on Windows 7 and 10. works great
door Binkhrs
2 commentaren meer tonen
