Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Modem Firmware Blank And No IMEI.
Hello Everybody in this great place. Please I am in serious need of your help, iPhone 5 was working in good condition before the mystery. It does not fall to the ground, the phone just went to stuck on searching where the network bar is. Things that I had done to help myself... I have set the time and date to the accurate, i have remove the battery to re-clip, adjust the time and date to correct one, i have reset the network setting on the iphone5 menu but searching still but the sad thing for me now is that the phone shows BLANK Modem Firmware and shows no IMEI at all, I am so much afraid to restore this phone on iTunes because i would not want the phone baseband Chip to damage because i cannot get the babaseband to replace here...
please I need advices about what steps should be taking or what i have to do to make my friends iphone5 work again with Sim network function.
Thanks in advance.
Is dit een goede vraag?
Score 28
2 opmerkingen
Did you get your problem fixed?
door
Hello teacher . 1 iPhone 5 baseband I'm the problem, and with Ryval the phone has been turned off.
Knyd.mmnvn's help
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I hope the baseband itself is not damaged as well because replacing the baseband chip is a lot harder than it already sounds. Not just the component sourcing and hardware repair procedure, the system main storage has to be reprogrammed as well to pair the baseband IMEI with serial number. It is very difficult and future upgrade may fail.
Usually it's just a power issue, the baseband power supply part is damaged. Find the broken part, replace a capacitor or inductor, or baseband PMU at most.
Was dit antwoord nuttig?
Score 7
6 opmerkingen:
thanks for your reply, i don't know whats wrong but i wrote a bigger message here early in the morning totally but it disappeared i cant understand why, i am new person here and i am new to hardware repairs most especially apple but i gather info from internet since i come from where there is no apple care center...
i have not even touched the iphone5 since morning because an expert engineer promised to help out with it but its sad for me he failed and now i am on my own on this phone and i dont want to do anything stupid, i dont know the terms you used and i so confused right now because the phone in question still show the bluetooth addres and wifi address correctly but the IMEI doesnt show and the modem firmware is BLANk...
pls help with maybe picture or schematic or something that can put me on the right vivid lane on this iphone issue because thinking about how it all happened gives me headache. your further help would be appreciated... if you skype my id is oluromeo... please reply.
door
Sorry i don't have repair data for iPhone 5. Maybe you can find a technician online and mail your phone to them.
door
Thanks for you reply, can you recommend an online technician or any link you can trust will be appreciated... thanks again.
door
Thanks. Very helpful :)
door
where the power supply part can you send a photo for th coils or capacitor and how i know the input for this ic ???for iphone 5s
door
1 commentaar meer tonen
i have the same problem. it happened 3 days ago. i've done everything. reset, upgrade, sim in sim out, all the thing that i can possibly do by my self...
finally i went to apple service centre. they said it is about a hardware issue. they should change one part of the chip in the firmware. it costs 120 USD to fix it. and my iphone has to stay there for 2 days...
so in my experience theres nothing to do except ask someone to replace the chip.
i have iphone 5 with ios 8.3.
Thanks.
Lisa
Score 4
1 Opmerking:
Were they able to repair the phone for $120?
door
Hello,
I'm in this case ! The only thing to do is Change the Motherboard INFORTUNATELY !!
Score 1
1 Opmerking:
Then all data will be gone
door
i did fit it just open it and heat it up like the 4s no wifi solution and it will show imei back dont know how long it will show but it worked for me
Score 1
Voeg je antwoord toe
Oluromeo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 101,735
