Ga door naar hoofdinhoud
Repair and troubleshooting information for the Suzuki FA50 Moped.
no acceleration,starts hard,need help
Bike starts hard and bogs on accelbcleaned carb,good spark etc...
Please help.
Is dit een goede vraag?
Score 4
1 Opmerking
I have the same problem, but my 50cc vip will only idle and thats at full to half throutle have tride 2 different brand new carborators, new top end rings the whole bit but same problem.
door
Voeg een opmerking toe
8 Antwoorden
Het nuttigste antwoord
How old is the gas in the tank ?
is it ready mixed or does the oil pump work (is the oil tank full?)
if the gas is older - change it, use the ready mixed one.
Was dit antwoord nuttig?
Score 2
I had the same problem, turns out the exhaust was plugged.
the previous owner was running with oil in oil tank AND premixed fuel creating quite a carbon deposit in the exhaust and oil. Cleaned it with a wire coat hanger and burned out the rest.
Score 2
2 opmerkingen:
A clogged exhaust will make you think the motor is being choked . It actually is being choked , just from the wrong end . ;)
door
Can I have fa50 run without a fuel filter
door
Could be that you are running super rich on your fuel/air mixture. Try leaning it out.
Score 1
You shoulddefinitely adjust the idle and air mixture screws if your FA50's not running well. Take a look at the carburetor diagram and make sure that the air mixture screw is 1 3/4 turns, as instructed, and that the idle screw is adjusted properly.
Honestly, I wasn't able to figure out how to set the idle to "1500 +/- 150 RPM," so I just ran the bike until warm and then adjusted the screw until it "sounded right" -- whatever sounded like it should be going at.
Also, make sure that the choke cable is completely off when running the bike, and especially while adjusting the idle / air mixture screws.
Score 1
you might want to check the compression. it should be between 100 to 125. if its low rebuild is in its future.
nick
Score 1
2 opmerkingen:
Mine was 30 so I put a bore kit on it now I'm rebuilding the carb because it sat for 5 months
door
mine is 90... cant keep it running. does it need a bore kit?
door
Make sure your transmission oil is clean if the acceleration is bad after you adjust the mixture. You'll be amazed how much this can slow you down.
Score 1
1 Opmerking:
Clean AND the correct oil as recommended in the manual .
door
If it smells rich you may want to change the spark plugs. Easy to do and should be done before mucking around with carby mixture. If you have had bad fuel your spark plugs suffer.
What is the trannys fluid? And recommend oil? Any 2 stoke oil?
1 Opmerking:
Trans oil use 10w30 synthetic, and use injection found at your local cycle shop, do not use 2 cycle oil you put in your chain saw or weedeater.
door
Voeg je antwoord toe
darren zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 10,211
