Why won't my phone charge
I tried positioning my charger in different ways while its charger and it won't charge and I took my battery out and put it back in it still won't charge
Is dit een goede vraag?
If you charger has a light on it, notice if the light illuminates when you plug it into a wall. If not your charger may be bad, try swapping that charger out with a new one and try not to bend the charger as it will ultimately damage the cable connector indefinitely.
If you are using the same outlet, try switching to a different outlet
If that doesn't work you may have a bad battery on your hands and may need a new one.
If you have a multimeter and feel confident enough you can check both the contact points of the charger and the cable connector on the phone, the voltage should be roughly around the same amount of power, the charger being a little above than what is stated.
You may have to change your phones cable connector for the charging cord, has anything happened to your device recently?
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 292
