Ga door naar hoofdinhoud
Possible on board RAM fault?
Just bought this machine and though it works fine the system profiler only shows 256Mb on board RAM when there should be 512Mb, and it doesn't chime on start up.
Are these two issues connected and how do I resolve the first one?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
3 Antwoorden
Gekozen oplossing
Assuming the sound on your laptop is functional you should be able to reset the volume level and thereby restore the chime sound by resetting the PRAM. But no, the two issues should not be related.
I've seen an iBook here and there show less RAM than it should actually have, so it's conceivable that a bad 1.42GHZ could be showing 256MB. It's hard to say whether that indicates bad RAM or not, but it probably does. A good test would be to add additional RAM and see if it registers correctly.
Was dit antwoord nuttig?
You must have the 256mb version of the iBook.
Go under the Apple in the upper left hand corner to "about this Mac". First see if it is a Apple iBook G4/1.33 14-Inch (Late 2004). That machine has 256mb of onboard RAM.
RAM Type: PC2100 DDR SDRAM Min. RAM Speed: 266 MHz
Details: Supports a single 200-pin PC2100 DDR SDRAM SO-DIMM memory module.
Standard RAM: 256 MB Maximum RAM: 1.25 GB
Details: The maximum memory capacity of this system is 1.25 GB with 256 MB onboard and a 1.0 GB SO-DIMM.
Voeg je antwoord toe
Peter Benson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 152
