Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Vraag afgerond
Microphone not working on calls but works in other apps?
I replaced the lock button flex cable (of course I have to replace everything attached to it like the volume buttons, ringer switch, rear noise-cancelling mic etc.) and now my microphone won't work in calls and most apps. Some apps I've found it works (snapchat is one).
I believe it is the rear mic (noise cancelling one) that has the issues? I tried replacing the part again and now the problem still persists, what is the issue/potential issue here?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
When on calls the phone uses the mic from the dock connector try replacing that
iPhone 5 Lightning Connector and Headphone Jack Replacement
Was dit antwoord nuttig?
2 opmerkingen:
When I was replacing the lock button etc part, the only time I would've touched the lightning connector and headphone jack part was when I disconnected it from the logic board, which I'm certain I wouldn't have damaged as I was very careful. It's not just calls that I have issues with, but other apps like Teamspeak, Voice Memos etc. don't work, then apps like Snapchat do work, why?
Thanks for your assistance so far :)
door
The mic attached to the power flex works when u record on the rear camera test that out..
Voice memos uses bottom mic
Cameras use both upper mics
door
I have same problem. I have iphone 5s and mic not working. I changed dock but Still same. Dis somebody now how to fix. Thank you.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 7,943
