Dead or blue screen after screen replacement
Hi!
I have changed a few iPhone 5S displays and the device is starting to scare me now.
Have had multiple devices with weird problems after screen replacement (but most of the time it works like a charm).
Why is this? What is it about the 5S thats so different from 5 and 5C.
Thanks!
Is dit een goede vraag?
Hi guys.I got the same problem after removed the screen and plugged in back.I tried to restore and then about 5% iphone got the blue screen and iTunes got error 14.Please tell me this is a problem of hardware.It really appreciates for me.Thanks for advice
door Huy Max
I have also same problem BLUE SCRREN...... How I can fix it?
door Mithun Dewan
I have also blue screen problem . Screen work fine until I connect the front camera cable. I had remove all screw several time and got same problem . Please help
door Naeema
There are usually 3 reasons for blue screen. The front camera and proximity flex cable may have been damaged, the home button connector may not be seated right, or you have screw damage from not putting in the right screws during a repair as it's very important to lay your screws out or use a screw mat so you don't mix them up. If you screw a long screw where a short screw should go can damage a logic board and it's a expensive fix.
door brucemicki
after dropping my iphone 4s i have a blue screen with like lines and stuff how much money does it take o fix it and or is it fixable
door Violet Silva
