Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
Damaged LCD top ribbon cable
Hello,
During the cleaning of my iMac 27" I accidentally damaged one of the top ribbon cables (the ones that connect the display to the little logic board attached to the lcd), is there anyway to replace this ribbon without soldering on the logic board?
It's the same problem as on this picture, same mac and the same mistake. Any ideas whether this is repairable?
Thanks.
Is dit een goede vraag?
Score 2
1 Opmerking
Any other ideas?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
faabamskeelb, that is not a LVDS cable. That is one of the TAB. LCD panels use TABs to connect to the driver boards. TABs are (tape automated bonding). It's called FFC/FPC. FFC is flexible flat cable, whereas FPC is flexible printed cable. This is what is referred to as the TAB's. Check Wikipedia if you need to get deeper into in. The repair of those is extremely difficult due to the size of it. Unless you have the ability and tools to microsolder, you will have to replace the LCD. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
That's very easily replaceable! Don't worry too much! I'll link a guide where you can fix it! It might be expensive but: iMac Intel 27" EMC 2390 Display Replacement
Score 1
5 opmerkingen:
Thanks for your reply, but that's replacing the entire LCD right?
My question is whether it's possible to fix just that damaged cable so that I can still use this display assembly...
door
Not unless you can find the specific cable online, if you do, you can follow that guide in replacing it!
door
Yeah that's part of the problem, I do not know what that cable is called exactly.. I know how to take the iMac apart up to the point where you see the cable, but I'm wondering if it's even possible to replace it without doing some micro soldering... Thanks again for helping
door
Oh, that's called an LVDS cable
door
Don't forget, if this was helpful, to mark this answer as Accepted!
door
Voeg je antwoord toe
faabamskeelb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 50
Altijd: 5,617
