Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Tips om optimaal van iFixit te genieten.
29 Vragen Bekijk alle
Where is the add comment link? What is O.Q.?
I was told I put a question where answers should be. But it said to use add comment link in O.Q. -
Where is the add comment link? What is O.Q.? Sorry, I'm confused.
Is dit een goede vraag?
Score 1
Commentaar:
I see an Add Comment link here but not in the question I wanted to discuss.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ReRe, ifixit is a bit different than most other forums. Here you have the chance to ask your own personal question, and receive an individualized answer. You would use the "Ask a question" tab to the right of the screen which will take you here http://www.ifixit.com/Answers/Ask/iFixit Then you ask your question. If you post a question either as an answer or a comment to someone elses question, it will get lost and you most likely will not get an answer. This is done so that the focus is on answering the original question only. O.Q. possibly means "other question" if you have posted more than one question. The add comment link is the light blue link just above the answers. Hope this explains it.
Was dit antwoord nuttig?
Score 5
Voeg je antwoord toe
ReRe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 231
