Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
1.6, 1.8, or 2 GHz G5 processor
172 Vragen Bekijk alle
iMac cpu fan running at 4400RPM after 20 minutes of use?
Hi,
My iMac G5 (Powermac8,1) cpu fan is running at 4400RPM after 20 minutes of use. It doesn't matter what I am doing.
I have zapped the pram, blew out the iMac with compressed air and have reset the power management unit.
Could the cpu need to have a new layer of thermal paste applied?
System Fan 1240 RPM
CPU Fan 4400 RPM
Hard Drive Fan 1800 RPM
HD 50º Celsius
CPU 62º Celsius
Hard Drive 47º Celsius
Please help this fan noise is too loud to work on the computer.
Thanks,
MaxTek
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Your CPU is running hot so it likely does need a new coat of thermal paste (also the age of the system warrants it as well).
A quick blow of can'ed air in its self won't do to much. Often you need to do some scrubbing with a soft painters brush (Don't forget about ESD). The heat sinks, fan blades and the power supply often need it the most.
Follow the IFIXIT guide iMac G5 17" Model A1058 Logic Board Replacement
Was dit antwoord nuttig?
Commentaar:
Thanks. I will tear it down and try that.
door
Voeg je antwoord toe
Jeff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 140
