Ga door naar hoofdinhoud
The Nokia N9 is a smartphone made by Nokia running on the Linux-based MeeGo "Harmattan" mobile operating system.
12 Vragen Bekijk alle
Screen is cracked and it won't turn on
I have a cracked screen nokia n9 is there anyway to fix a phone like that? It's an internal memory phone the screen is broke and it won't turn on.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I think you may have damaged your LCD while dropping it or the cable became undone.
Was dit antwoord nuttig?
Score 1
you can replace the display assembly on a nokia n9. all steps are detailed in nokia service manual.
most of the time a nokia n9 that will not turn on is due to a discharged battery. you can force charge it by using flasher utility.
start the flasher utility, then plug your device and do nothing else but wait. this is a trick to force charge of a nika n9 battery was discharged too low. consider replacing the battery if this happens often.
Voeg je antwoord toe
Collin Johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,241
