Ga door naar hoofdinhoud
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Vragen Bekijk alle
Vraag afgerond
Compatible Logic Board for MacBook Core Duo 2.0 GHz
The fan on my Macbook 1,1 2.0GHz Dual Core is pretty much running a high speed all the time. Apple says I need a new logic board. Do I have to get an exact replacement or are there compatible logic boards with Core 2 Duo processors that I could upgrade to?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Stay with a model A1181 logic board and you should be fine.
http://everymac.com/ultimate-mac-lookup/...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
do you have first-hand knowledge of this? i could get either :
MacBook "Core 2 Duo" 2.0 13" (Black)
2.0 GHz Core 2 Duo (T7200)
or
MacBook "Core 2 Duo" 2.16 13" (Black)
2.16 GHz Core 2 Duo (T7400)
Don't i need to worry about energy star compliance and wiring compatibility? looking for a definitive answer before i go buying logic boards in hopes they'll work. i don't mind if i have to frankenstein my macbook a bit if it means i can keep it running for a few more years.
door
I can't say with 100% certainty that this is true, however I do have first hand experience repairing and/or refurbishing hundreds (possibly 1,000+) MacBooks. With that in mind, it's my experience that Apple frequently changed mounting locations and made small revisions between MacBook generations.
For instance a logic board from an Early-2008 MacBook might physically fit and bolt into a Late-2008 MacBook, but the bluetooth connection on the logic board may be a different type. Alternately the logic board may not fit due to mounting points in the bottom case being slightly different.
Thats just one example but it often holds true, especially with the very early MacBooks (yours is a first generation) as Apple made lots of revisions in the first few years. The fan connection, bluetooth connection, speaker connection, optical drive connection, etc all changed pretty early on.
Unless you have physical access to several logic boards to test before hand I would recommend you stick with the logic board intended for your Mac.
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 219
