Ga door naar hoofdinhoud
Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2997 Vragen Bekijk alle
When I removed the battery contact clip I pulled 4 pins off?
I was replacing the battery on my iPhone, following directions, and when I went to remove the contact clip four of these pin came off. They seemed to be sautered on the motherboard. I have read about this problem before, others ripped off the pins as well as metal squares too. I think that in the ifixit directions for a battery replacement, something needs to be added warning fixers, "be extremely careful when detaching the contact clip, so you do not damage the motherboard.
**Photos attached
Is dit een goede vraag?
Een opmerking toevoegen
iPhone Batterij Fix Kits
Slechts $29.99
Buy Now
Slechts $29.99
Buy Now
2 Antwoorden
Het nuttigste antwoord
I don't see pictures. But did you pry carefully and remember to unscrew stuff? If you did rip connectors off then you need to have mad skills with soldering to repair it, although I have seen people advertise that they repair it on ebay (don't know if they are good though). If you fix the images, I can be more help.
Was dit antwoord nuttig?
Score 1
Commentaar:
I have re-uploaded the pictures. yes I remembered to unscrew stuff, but I might off pried to hard.
door
the solders are clearly broken, so if you don't have the necessary skill (or desire to learn), you are pretty much limited to paying someone else to fix that issue. sorry to bring the bad news
door
This isn't hard for a professional to fix--eBay $30
Feel free to contact me if you'd like some tips to try it yourself.
Jessa
Score 1
Voeg je antwoord toe
Blake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 147
