Ga door naar hoofdinhoud
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
111 Vragen Bekijk alle
windows 8.1 with current Itunes software wont recognize iPod
up until today I could plug my ipod on my computer and Itunes would do its thing, today I plug in and Itunes loads but it tells me that it can't recognize my Ipod nano. I have removed and re-installed Itunes and still not luck.
Is dit een goede vraag?
Score 3
2 opmerkingen
I can not burn a disc with iTunes and windows 8.1
door
Can you please tell me if u can connect an iPod nano 7th generation to a windows computer?
door
Voeg een opmerking toe
11 Antwoorden
Gekozen oplossing
I was facing the same issue after upgrading to Windows 8.1. You need to remove EVERYTHING that has anything to do with iTunes to fix this problem. Make sure to remove Apple mobile device support, bonjour, Apple software update, Apple application support and of course iTunes. This article will help you to remove everything: http://support.apple.com/kb/ht1923
Now re-install the iTunes software and you’re good to go. I hope it helps.
Was dit antwoord nuttig?
Score 8
4 opmerkingen:
I am experiencing the same issue, but hesitate to totally uninstall Itunes since I have nearly 1000 manually added Album Covers for albums created by converting my vinyl records to mp3's.
Anyone know how to retain that customization?
door
I have done this 5 times and its still not working. The apple "genius" people have tried as well and the driver still wont install properly. Any ideas on how to fix this before I go spend a fortune on computer techs?
door
Stupid. I have the same problem. Installed itunes for the first time then plugged in the brand new ipod and got the same problem. So, the reinstall software, reboot computer crap is incompetent tshooting. If this does work which I will not try then I am returning the ipod.
door
Thank you! It worked for me too.
door
I removed everything as you suggested and re-installed Itunes, it worked!
Thank you for taking the time to answer, you have saved an HP windows computer from being listed on craig's list, under the heading, "computer junk for sale"
Thank you Alex22 for your help.
Score 1
1 Opmerking:
I'm glad I was able to help.
door
Had the same problem, and this fix worked for me too! Thanks!!!
Score 1
It worked, thanks!
Score 1
It worked by uninstalling ALL Apple programs and components. Thank you! I had uninstalled and re-installed iTunes several times, without success. However, it worked like a charm after uninstalling Bonjour and all other Apple programs and then re-installing iTunes.
Score 1
thank you , working good now
Score 1
It worked for me as well. Win 8.1 with the same troubles of iPod & iPod Nano did not connect to the item, but succeeded to connect to the computer. Fulfill the instruction above worked like a magic. I'm sorry I didn't find this article before spending 3 hours for nothing.
Thanks
Score 1
THIS is the real solution to the problem at hand. Thank you very much.
Score 1
Worked a treat!
I was similing before I've done it... In my mind was what a bunch of crazy guys :)))
But I was so wrong. Sorry guys.
Worked perfectly.
Thank youuuu
It works................except! If you have 2 ipod devices then it will recognize one but not the other. You have to go to the control panel and update the ipod device driver and reboot each time you switch ipods.
Voeg je antwoord toe
Javier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 23,478
