Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
867 Vragen Bekijk alle
My iPod 5th Generation (Video) will not get off of hold!
One day, I placed it in hold so it can stay off and not loose charge while I was in school. When I take it out and pushed back the hold button, it would get off of hold. No matter how many times I push it, the hold sign doesn't do away and I can't press anything.
When I connect it to the computer, it turns on and connects to iTunes as usual but it is still stuck on hold.
Help!
It's a iPod 5th Generation (Video) with 30GB of memory D:
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
Rosa, two things that may have happened. Open your iPod following this guide. 1.Check to make sure that the hold switch is still engaged at the cable. If so, then 2. start by replacing the flex cable. Also, of course, make sure that it is properly inserted at the connector on the logic board. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rosa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 39
