Ga door naar hoofdinhoud
Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
3017 Vragen Bekijk alle
No power to device
So a customer has come with a dead iPhone, tried a new battery, connector and still nothing.
So what bits should I be looking at next. I read the 3Gs but as the boards are so different I wondered if anyone could give me some tips on what to be testing i.e. pins and diagram of the locations of the pins
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Is the dead battery icon popping up at all when plugged in? If not, I recommend getting 91% isopropyl alcohol and brushing some into the charging port with an unused tooth brush. I've seen this problem many times and the cause of it is corrosion on the charging pins. Hope this helps!
Was dit antwoord nuttig?
Voeg je antwoord toe
Cammy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 60
