Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
431 Vragen Bekijk alle
Needing an acceptable harddrive replacement.
I've been reading and it seems that either 1TB Drive or 2 TB Drive might work.
Also it's mentioned on those two items that on some computers you must use the same brand as came with it. Can anyone confirm for me that won't be an issue with my 24" iMac?
1 TB 7200 RPM 3.5" Hard Drive Afbeelding
Product
$69.99
2 TB 3.5" Hard Drive Afbeelding
Product
$149.99
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The 1 TB drive will probably give you the most value. I've never run across any Mac that needed the same brand of hard drive. I know of no reason to use the same brand of drive. Just make sure it's a SATA.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
The 1.5 TB is also attractive: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-088-1]
door
+ Ralph
door
Shure, thats what standards are for +
door
Voeg je antwoord toe
Bryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,505
