Ga door naar hoofdinhoud
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 Vragen Bekijk alle
PSP backlight not working
I have a PSP 1000 and the problem is the back light. I tried replacing the whole screen but the back light is still not working. So I am 100% positive that the problem is actually the motherboard, but everything else is working fine. I have tried the fuse fix but that didn't work either. Has anybody tried grabbing the voltage from another location within the motherboard? any suggestions on where to grab voltage from?
Is dit een goede vraag?
Score 1
2 opmerkingen
I did check the voltage where the back light goes and it gives me zero volts, and there is continuity in its proper fuse.
door
Did you test the points where the back light would get power from with a multi meter?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check this video and here great instructions in getting your backlight back. There are multiple fuses on the board, make sure that you check the right one.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
tehsalt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 9,113
