Why not Epson C44 plus printer Teardown
I see very mutch divecs in your nice homepage but any printer repaire or Teardown
why not ?
tnk you
Is dit een goede vraag?
why not ?
tnk you
Randy sounds to me like your printhead needs to be cleaned first. But anyhow I did find some info about the oiling and included it here.
Try wiping the bar with a lint free cloth and also clean the outside of the metal bushings that the carriage bar passes thru on both sides of the holder assembly. Then lube the metal bar on both sides of the holder assembly, slightly with a precision oiler. A drop or two of a silicone or teflon based lubrication is best, but even a household 3 in 1 type oil can be used. Manually slide the holder assembly back and forth to spread out the lubrication and wipe of any excess lube or blackish build-up that appears on the bar.
And this might help in how to clean your printhead.Print heads become blocked for a number of reasons, but the most common is simply that the ink cartridge has dried out, and so has the print head. Anyway, here are a few hints and cleaning methods that MIGHT get things working again.
o Soak the print head in hot water then leave it overnight, then try it again
o If you have access to an ultrasonic cleaner that will take the printhead, use that. (These are used by jewellers and other people which have to clean small, intricate parts)
o Buy some Isopropyl Alcohol and soak the printhead in that overnight.
o Use a Mr Cuppacino (or your Espresso machine). It's a small kitchen appliance which creates a jet of steam for frothing milk for making a cappuccino. You can use the jet of steam to blast the print head. But be careful that you don't melt things -- short, sharp jets only.
o Each time you try a cleaning method, use a damp paper towel to gently wipe and dry the print head area.
and since I do not have any fancy pictures I also include a quick step-by=step teardown of the service station.
I'm giving you the complete service station removal and cleaning instructions. All you have to do to observe the service station is remove the case.
Before You Begin
You will need a T10 Torx driver and some latex gloves if you want to avoid getting ink on your hands once the case has been removed.
Remove the Case
1. Remove the two screws in the top of the case
2. Remove the rear access door and press the release tab in both upper corners of the opening.
3. Open the hinged cover and release the two "claw" latches using a slot screwdriver. One is in front of the Service Station and the other is on the opposite side in the same relative position. These are a bit tricky to release but patience will prevail.
Remove the Power Supply
1. Remove the power-input plug from its bracket by pressing the two latches
2. Remove the screw securing the power supply and the plastic box surrounding it.
3. From the front in the general area of the carriage belt, depress the latch that holds the box and power supply in place and slide the assembly out horizontally.
Removing the Service Station
1. Unplug the connector from the carriage drive motor.
2. Unplug the connector from the main electronics board.
3. Viewed from the front, remove the red screw from right side of the service station.
4. Remove the screw in the vertical frame to the right of the carriage drive motor.
5. Remove the screw in the vertical frame to the left of the belt tensioner.
6. Looking from the top, remove the two screws going through the carriage rod.
7. The vertical frame will now hinge up and come free of mechanism.
8 Looking from the front, there is a large latch on the right side of the service station. The wiring obscures it. Using a slot style screwdriver, release the latch and the service station will rotate CCW and lift out. Unplug the motor connector to free the service station from the mechanism.
Cleaning the Service Station.
1. Remove the service station motor by removing one screw.
2. Scrap as much congealed ink as possible from the service station.
3. Immerse the service station in hot water to dissolve the remaining ink. This will take a while but after a few rinsings nearly all of the ink will be removed.
Hope this will help you with your printer. Good luck and let us know.
Was dit antwoord nuttig?
good question - but i think that printers are sometimes very hard to open and it cann be a really messy job.
the old, dried, smeary ink can be a real pain (you know where)
i've fixed a few inkjet printers - but only for friends - for good friends - this is definatly a job i didn't want to do every day.
but hey - that wasn't the question ;-)
maybe you could start to make a teardown of your epson c44plus ;-)
and btw - do you have a problem with your printer ?
;) you find it markus
lol
yes the mecanisme in my printer have some dust but
it work now
i think i wen to do some teardown but not for my printer caus i work with it
thk you and see you next
nice job you do ^^
bedji
No one has made one yet! Take some photos when you work on yours and get one started!
lol
it work now
nice job you do ^^
bedji
I have a HP 932c that has been a very reliable and great printer but lately its messing up. I think the rail just needs oiling, any other ideas or how do you go about oiling the rail, and would 3in1 oil be best?
Thank you old for the printhead cleanup instructions. I did hook it back up and ran it, it's not doing what I had thought. It's either a dirty printhead or the paper is not advancing at a constant pace through the rollers. Its skipping (at times) when printing for a whole pass as the head passes across the paper. I did notice build up on the small metal rollers over the rubber pick up rollers for the paper. I cleaned those off, ran it and it seemed to work ok again. It is either that or the printhead like you are saying. Will run it as is for awhile and if it starts acting up again I will do the printhead clean instructions that you supplied.
Again thank you for the help and information.
Randy
Randy what makes you think that you printer needs oiled? What is going on with it? I honestly have never heard of any oil on a printer, but that is not to say that it is not the right thing to do....:)
Randy, glad I could help. all the best to you with your printer.
Remember to return and mark accepted the answer that best solves your problem.
I haven't used it for about 4 months now, I switched over to my other printer but from what I can remember it was (this is hard to explain) blurring the printing by shifting it ever so slightly over and down just a bit. I would have to hook it back up and run it again to make sure but to the best of my memory that is what it was doing. I was able to print several more pages out of it due to the size of the print cartridges than I can out of the HP all in one I have now. I have done nothing with it, was told by someone it may just need cleaned and oiled. Any advice is appreciated.
wouldent hurt to but can be messy so work on a surface you can care less staining,junk clothes,and gloves(my procedure when i do ink refills)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,862
