Ga door naar hoofdinhoud
Acer Aspire 3050 laptop.
9 Vragen Bekijk alle
lcd display sometimes black and sometimes ok
I have laptop which from time to time, when i turn on have a black screen. It look like a LCD backlight dosn't work properly. Any sugestions what is wrong.
thanks for any help Robert
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
chmielu chmielewski, this could be caused by a bad LCD panel, which houses the backlight itself, or a bad inverter. I would start with the inverter. It is less expensive and a bit easier to work on. Cost for the inverter is around $15US. Hope this helps, good luck.
Was dit antwoord nuttig?
2 opmerkingen:
I'm thinking about problem with inverter, tell me can i use invertor from another laptop with the same size of lcd
door
Thank you for accepting my answer. The part number is AS023170775 and it should be compatible with Acer Aspire 3680 5050 5570 5580 5585WXMi
Acer Travelmate 2480 series
Acer Travelmate 8100 Series LCD (8103WLMi, 8104WLMi) Model ZF1
Acer Travelmate 8200 Series LCD (8202WLMi, 8204WLMi) Model ZC1
Ferrari 4000 Series (4002WLMi, 4005WLMi) Model ZF3
Ferrari 5000 Series (5005WLMi)Model ZC5
Acer Aspire 4520 4520G 4720 4720G
door
Voeg je antwoord toe
chmielu chmielewski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 621
