So i have replaced the digitizer board ribbon that connects to the main board. I found that two of the contact points were bent up and peeled back or tweaked. SO i replaced that.
So for all who are taking notes.
broken lcd problem, replaced lcd while replacing cracked digitizer. Touch started working spotty if not at all.
replaced digitizer, touch not working at all. checked and rechecked ribbons.
Replaced main digitizer - main board ribbon. no touch. rechecked all connections.
next step.... replace digitizer board? I guess its at this point. The only thing i can figure is the bent/tweaked connections on the main ribbon shorted the board?
One question i have and cant remember is could the lcd be the wrong version? I know the digitzers make a difference. And i have the exact match of digitizer. But i did not know of other versions of LCds. I have not heard that there is other versions just I wonder if there is and that is why the touch is not working.
On you tube there is a video of a factory repair where the factory sent it back to the owner saying they could not find out the problem. And it has a no touch problem also. I hope that is not the case or else im buying a new tablet for someone.
I replaced a screen and now there is a cursor jiggling around in a small selection frame in the upper-right region of the screen. Device Manager says everything is fine.
anyone else got that? i definately don't want to jump a fuse if that's not the problem.
door asteroidmeteorite
I have the same problem. X202E Replaced digitizer 2 X replaced digitizer cable & ribbon connection board that attaches to the digitizer. It appears that the digitizer is being depressed in multiple locations in the upper to mid right potion of the LCD. I'm lost? I looked to see if anything was there that might be "warping" the digitizer but I see nothing. Any ideas?
I do work on laptops constantly but this is my first foray into touchscreen repair.
door Walter Stutler
hye, I need the picture of the PCB Board to know where is the microfuse of it, coz the touch screen of my tf300t doesn't work. please help me to solving my problem. i hope you send me the link where i foud it. thanks a lot for helping. gurigjiri
door guri gjiri
Hi,
I have a HP PAVILION X360 and I smached the lcd and digitizer and replaced both, but i replaced the digitizer with a non-touch digitizer but I was wondering if I replaced the digitizer with a touch digitizer would the touch start working or not.
-THX-
door Badboyjuni
