Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Vragen Bekijk alle
My iPhone 3GS after restoring it only showed apple symbol
my iphone 3gs after restoring it only showed apple symbol and I left it whole night in the morning i saw my phone is switched off. i tried to trun on my iphone but it showed my battery red and a pulg in charging symbol. i pluged in charging to my loptop but my phone does not show any charging symbol the screen is black. i pluged it for about an hour. even it shows the same symbol and it is not getting charged. plz help me to restore and charge my iphone
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
pramod, clean your dock connector with some isopropyl alcohol etc. of any dirt or debris. Check the dock connector for any bend, broken or corroded pins. Try another cable to ensure the one you have works. Try to charge your iPhone on an AC adapter. If none of that works, replace the battery and re-evaluate. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
pramod zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 74
