Ga door naar hoofdinhoud
Vraag afgerond
this computer can only take 3GB max.
I ordered 2x2GB sticks before I knew better, only to discover that this computer can only take 3GB max. Fortunately, I was able to return one of them and kept one of the original 1GB sticks in the other slot, for a total of 3GB (which works fine).
Is dit een goede vraag?
4 opmerkingen
What do you mean by "interleaf" when using two 2GB sticks?
door
Maybe this will help explain Wiikipedia - Interleaved Memory
door
Thanks for the link. Do the two sticks have to be the same brand for it to work, or just the same capacity?
door
You want a matched pair (same brand & series)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your system can support both 2GB sticks, yes it will only use the 3GB. But that 1GB loss offers interleaf were as using the one 1GB & one 2GB sticks loose that. Don't forget to update your EFI firmware.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 139
