Possibility of fixing the left SHIFT-key
My left SHIFT-key is broken. It behaves like it would always be pressed. So the Computer always starts in the secure mode which is awfull. At first I tried with little access to remove the key and lift and to bring some distance between the layers of the key. It worked only for two hours and could be repeated only twice.
A new keyboard installed by the german apple-service would cost me more than 500 bucks. Is there any possibility even with the loss of the left SHIFT-key to fix the problem.
Is the only way to fix it to change the uppercase?
Is there any software-solution for my problem?
Is dit een goede vraag?
1 Opmerking
If you get a chance think about changing the accepted answer to Machead3 as it sounds like his remapping software got you up and going. Glad things worked out. Keep your eye on ebay for a replacement keyboard from a dead machine.
door Ken
