How do I fix my DVD Drive from scratching discs?
Question in the Topic!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
Aahd Tahar, seems to be a known occurrence in consoles released around 2005. Check on here for reasons as well as possible solutions. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Commentaar:
Well , I did that , but people are saying my DVD Drive tray is unstable. How do I fix that problem?
door
when you read the issues addressed in the link did you notice "The disc spins very close to the pickup and the tray does not prevent the disc from reaching the laser pickup. If you are experiencing scratched discs without moving your console you should contact 1-800-4MYXBOX for warranty support from Microsoft." there is no real fix out there other than something like the foam block suggested with the above link. Of course you could try a new optical drive, just remember that a new one is tricky to install since it most likely will have to be flashed, or the PCB changed.
door
Voeg je antwoord toe
Aahd Tahar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 13
Altijd: 1,544
