Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
19945 Vragen Bekijk alle
Vraag afgerond
Why my MacBook Pro battary seems to be disconnected?
I have Macbook Pro 13 inch late 2011, when I plug the charger to my mac sometimes no color , sometimes become green and suddenly the color disappear , sometime orange and suddenly disappear, when i press battery status bar on the left shows the battery is empty
currently I can not start my mac at all.
I have doubt that the problem from MagSafe DC-In Board but still can not confirm.
please help me to troubleshoot
(note: I have tested the charger with other mac and i works perfect)
Is dit een goede vraag?
1 Opmerking
Actually Yes ,, I squeeze it accidentally
how did you fix it ?did u flexed it back to the original condition with you hands ??
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I suspect damage to your battery. If the laptop has been squeezed in to a tight space, or had something stacked on it, or dropped you could have cracked the battery case. I had a MacBook Air with intermittent, occasional battery problems... not charging, not starting then suddenly working fine for a bit.
I had to open the machine and lift out the battery in order to discover the crack. The battery looked normal when observed in situ but as I lifted it, it flexed, so I spotted the cause of the trouble.
I thought back to when someone had placed something on top of my laptop case in an overhead airline bin... that's about when the problem started.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 139
