Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
319 Vragen Bekijk alle
After drop, screen has transparent grey bar, can I fix?
I dropped my mackbook air after which the screen displays a vertical transparent grey bar across most of the screen width and some flickering lines at the top and bottom. I can still see enough to use it but the grey bar etc.is inhibiting.
When the background is white there is no apparent interference although the colours are a bit washed out under the grey bar. The problem is awful when the background colour is grey with many flickering horizontal lines.
I have checked the connector to the screen and it appears to be locked correctly.
Do I need to replace the display?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
iPhone Batterij Fix Kits
Slechts $29.99
Buy Now
Slechts $29.99
Buy Now
2 Antwoorden
Gekozen oplossing
Sorry to tell you your LCD screen has become damaged.
The driver chips have a bad solder joint or burn't and/or the flex circuit board that ties into the LCD has become dislodged from the fall.
In any case its' time for a new display. To verify this connect an external display to your system if the bars don't show up that verifies it.
Was dit antwoord nuttig?
Score 2
Commentaar:
Thanks Steffen and Dan. I have checked with an external display and that looks fine. So I have to replace the screen again having only just replaced it a few months ago. Doh! how clumsy am I. :o(
Again many thanks
door
Het nuttigste antwoord
Hi John,
It could be a software issue or a hardware problem. Check out this link.
My guess is that it is a hardware issue and the display got damaged. But check out the computer by connecting it to an external monitor first.
Steffen
Score 2
Voeg je antwoord toe
John Mulvaney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 11
Altijd: 3,425
