NIC ports are blinking green but the station won't start
Hi,
My AirPort Extreme started restarting itself repeatedly so I disconnected it from the power supply for A few minutes and then plugged it back again.
Since then the unit Ethernet ports are blinking green but the station main front light remain off.
What can I do? How do I make it work again?
Thanks,
Tal
Is dit een goede vraag?
5 opmerkingen
I have the same issue.... Does anyone know if it could occur when the battery is dead? (I don't see any damaged part or solder on the logic board...)
door remyleroy
I have the same problem. The unit is 9 years old, so I already bought a replacement. The problem here occurred after we shut down the power and after restating the power the problem occurred. Maybe this can be a back-up battery problem? Hope to get it working again, so I can use it as a repeater.
door hengelr
I bought an replacement adapter on e-bay and it works again!! I'm using it now to extend my network. Saving €100 for an Airport Express :-) Thanks!!
door hengelr
فروش گيفت كارت ايتونز، كوگل پلي، پلي استيشن، استيم، ايكس باكس ، امازون، ويزاكارت و مستركارت درفروشگاه http://www.Egiftcard.ir
گيفت كارت معتبرراازفروشگاه معتبرخريدنماييد
door imansalmani
I had this problem, the power supply was outputting 12V when measured with a multi meter, but the power light of the airport Extreme was not coming on. The green lights on the ethernet port were flashing though.
I bought a replacement power supply from Amazon, and now it is all back up and running again.
door keithellis
