SSD will not show up after installing
I bought the second HD kit just after purchasing the Mac in 2011 and installed a 1TB second drive. Ended up removing that drive and the stock drive as well and installing an 80GB SDD that worked perfectly until I ran out of space due to the data files for a massive iTunes library stored on a 4TB external drive. I installed a second 80GB SSD as a user drive to solve the space problem and used the drive utility to combine the original 80GB back into one partition. When I installed the OS the new drive would not show up in any utility or the terminal. I finally installed the OS on the new SSD and both drives were available, however the online reinstall would only install lion not mountain lion. When I upgraded to mountain lion I would get a grey screen only able to safe boot. On safe boot all drives are available. I switched back to installing the OS on the original drive but again lost the new SDD.
Sorry for the long winded description as I saw no other problem here that exactly matched this.
Also the 2 SDD and one external HDD is the configuration I plan to use so please no answers suggesting different drives or configurations unless you know my configuration will not work.
Is dit een goede vraag?
9 opmerkingen
Mountain Lion offered Fusion Drive services, is it possible the OS installer is confused as it was expecting an HD - SSD Vs SSD - SSD setup.
door Dan
I have read a dozen articles on replacing the internal HD with two SSD's. It appears there is a specific procedure but no one says why you need to follow them. I may have found out why. Is it that the Mac was not built with two SSD's and having issues with recognizing them? How do I fix my problem if that is the case?
door Radjin
I do think the OS installer is the issue here as I'm sure Apple never thought to test it with a double SSD setup. You really need to talk with a Genius at an Apple Store to push this up the food chain (they won't charge you for this).
door Dan
FYI - You're not the only one having issues with a dual SSD setup Two SSD drive Raid 0
door Dan
Yesterday I had a chance to speak with our corporate Apple rep. He'll put in a call to his advanced support contact in Apple HQ. I'll let you know what I find out.
door Dan
4 commentaren meer tonen
